299. Ahart, M., M. Somayazulu, R.E. Cohen, P. Ganesh, P. Dera, H.k. mao, R.J.
Hemley, Y. Ren, P. Liermann, and Z. Wu. (2008) Origin of morphotropic
phase boundaries in ferroelectrics. Nature Materials Letters,
451, 545.
298.
Amulele, G., M.H. Manghnani, S. Marriappan, X. Hong, F. Li, X. Qin, and
H.-P. Liermann. (2008) Compression behavior of WC and WC-6%Co up to 50
GPa determined by synchrotron x-ray diffraction and ultrasonic
techniques. J. App. Phys., 103, 113522.
297.
Bass, J.D., S.V. Sinogeikin, and B. Li. (2008) Elastic properties of
minerals: A key for understanding the composition and temperature of
Earth's interior. ELEMENTS, 4, 165.
296.
Chow, P., and B. Friedman. (2008) Low-energy nonresonant x-ray
scattering of C60. Phys Rev. B., 77, 073406.
295.
Cornelius, A.L., R.S. Kumar, M.K. Jacobsen, E.D. Bauer, J.S. Sarrao, and
Z. Fisk. (2008) Magnetic ordering in UCu2Si2 at
high pressure. Physica B, 403, 940.
294.
Crowhurst, J.C., A.F. Goncharov, B. Sadigh, J.M. Zaug, D. Aberg, Y.
Meng, and V. Prakapenka. (2008) Synthesis and characterization of
nitrides of iridium and palladium. J. Mater. Res., 23, 1.
293.
Cuk, T., V.V. Struzhkin, T.P. Devereaux, A.F. Goncharov, C.A. Kendziora,
H. Eisaki, H.K. Mao, and Z.X. Shen. (2008) Uncovering a pressure-tuned
electronic transition in Bi1.98Sr2.06Y0.68Cu2O8+δ.
Phys. Rev. Lett., 100, 217003.
292.
Ding, Y., D. Haskel, S.G. Ovchinnikov, Y.-C. Tseng, Y.S. Orlov, J.C.
Lang, and H.K. Mao. (2008) Novel pressure-induced magnetic transition in
magnetite (Fe3O4). Phys. Rev. Lett., 100,
045508.
291.
Emmons, E.D., N. Velisavljevic, J.R. Schoonover, and D.M. Dattelbaum.
(2008) High-pressure raman spectroscopy and x-ray diffraction studies of
a terpolymer of tetrafluoroethylene-hexafluoropropylene-vinylidene
fluoride: THV 500. Appl. Spectroscopy, 62, 142.
290.
Errandonea, D., R.S. Kumar, X. Ma, and C. Tu. (2008) High-pressure X-ray
diffraction study of SrMoO4 and pressure-induced structural
changes. J. of Solid state Chem., 181, 355.
289.
Errandonea, D., D. Santamaria-Perez, A. Vegas, J. Nuss, M. Jansen, P.
Rodriguez-Hernandez, and A. Munoz. (2008) Structural stability of Fe5
and Ni2Si studied by high-pressure x-ray diffraction
and ab initio total-energy calculations. Phys Rev. B.,
77, 094113.
288.
Gavriliuk, A.G., V.V. Struzhkin, I.S. Lyubutin, S.G. Ovchinnikov, M.Y.
Hu, and P. Chow. (2008) Another mechanism for the insulator-metal
transition observed in Mott insulators. Phys Rev. B., 77,
155112.
287.
Kubo, A., B. Kiefer, S.-H. Shim, G. Shen, V.B. Prakapenka, and T.S.
Duffy. (2008) Rietveld structure refinement of MgGeO3 post-perovskite
phase to 1 Mbar. Am. Mineral, 93, 965.
286.
Kumar, R.S., X. Ke, A.L. Cornelius, and C. Chen. (2008) Effect of
pressure and temperature on structural stability of potential hydrogen
storage compound Li3AIH6. Chem. Phys. Let.,
460, 442.
285. Kumar, R.S., E. Kim, and A.L. Cornelius. (2008) Structural phase transitions in
the potential hydrogen storage compound KBH4 under
compression. J.Phys. Chem. C, 112, 8452.
284.
Lee, S.K., J.-F. Lin, Y.Q. Cai, N. Hiraoka, P.J. Eng, T. Okuchi, H.K.
Mao, Y. Meng, M.Y. Hu, P. Chow, J. Shu, B. Li, H. Fukui, B.H. Lee, H.N.
Kim, and C.-S. Yoo. (2008) X-ray Raman scattering study of MgSiO3
glass at high pressure: Implication for triclustered MgSiO3
melt in Earth's mantle. Proc. Nat. Aca. Sc., 105, 7925.
283.
Lipinska-Kalita, K.E., P.E. Kalita, C. Gobin, O.A. Hemmers, T. Hartmann,
and G. Mariotto. (2008) Stability and equation of state of a
nanocrystalline Ga-Ge mullite in a vitroceramic composite: A synchrotron
x-ray diffraction study. Phys Rev. B., 77, 134107.
282.
Lipinska-Kalita, K.E., P.E. Kalita, O.A. Hemmers, and T. Hartmann.
(2008) Equation of state of gallium oxide to 70 GPa: Comparison of
quasihydrostatic and nonhydrostatic compression. Phys Rev. B.,
77, 094123.
281.
Lucas, Matthew S. (2008) Cluster expansion applied to inelastic
scattering experiments, California Institute of Technology.
280. Lundin, S., K. Catalli, S.-H. Shim, V.B. Prakapenka, M. Kunz, and Y.
Meng. (2008) Effect of Fe on the equation of state of mantle silicate
perovskite over 1 Mbar. Phys. Earth and Planet, 168, 97.
279.
Martin*, C.D., Y. Meng, V. Prakapenka, and J.B. Parise. (2008) Gasketing
optimized for large sample volume in the diamond anvil cell: first
application to MgGeO3 and implications for structural
systematics of the perovskite to post-perovskite transition. J. Appl.
Cryst., 41, 38.
278.
Meng, Y., P.J. Eng, J.S. Tse, D.M. Shaw, M.Y. Hu, J. Shu, S.A. Gramsch,
C. Kao, R.J. hemley, and H.-K. Mao. (2008) Inelastic x-ray scattering of
dense solid oxygen: Evidence for intermolecular bonding. Proc. Nat.
Aca. Sc., 105, 11640.
277.
Reichmann*, H.J., S.V. Sinogeikin, and J.D. Bass. (2008) Single-crystal
elastic properties of (Mg0.987,Fe0.013)
O to 9 GPa. Am. Mineral, 93, 1306.
276. Sanchez-Valle*, C.*, Z.A.D. Lethbridge, S.V. Sinogeikin, J.J.
Williams, R.I. Walton, K.E. Evans, and J.D. Bass. (2008) Negative
Poisson's ratios in siliceous zeolite MFI-silicalite. J. Chem Phys,
128, 184503.
275.
Shim, S.-H. (2008) The Postperovskite Transition. Annu. Rev.Earth
Planet. Sci., 36, 569.
274.
Singh, A.K., H.-P. Liermann, Y. Akahama, S.K. Saxena, and E. Menendez-Proupin.
(2008) Strength of polycrystalline course-grained platinum to 330 GPa
and of nanocrystalline platinum to 70 GPa from high-pressure x-ray
diffraction data. J. App. Phys., 103, 063524.
273.
Somayazulu, M., J. Shu, C.-s. Zha, A.F. Goncharov, O. Tschauner, H.k.
Mao, and R.J. Hemley. (2008) In situ high-pressure x-ray diffraction
study of H2O ice VII. J. Chem Phys, 128,
064510.
272.
Stevens, L.L., N. Velisavljevic, D.E. Hooks, and D.M. Dattelbaum. (2008)
Hydrostatic compression curve for triamino-trinitrobenzene determined to
13.0 GPa with powder x-ray diffraction. Prop. Expl. Pyrotechnics,
33, 286.
271.
Tschauner, O., B. Kiefer, H. Liu, S. Sinogeikin, M. Somayazulu, and
S.-N. Luo. (2008) Possible structural polymorphism in Al-bearing
magnesium silicate post-perovskite. Am. Mineral, 93, 533.
270.
Zha, C.-S., K. Mibe, W.A. Bassett, O. Tschauner, H.-k. Mao, and R.J.
Hemley. (2008) P-V-T equation of state of platinum to 80 GPa and 1900 K
from internal resistive heating/x-ray diffraction measurements. J.
App. Phys., 103, 054908.
269. Campbell*, A.J., C.T. Seagle, D.L. Heinz, G. Shen, and V.B.
Prakapenka. (2007) Partial melting in the iron–sulfur system at high
pressure: A synchrotron X-ray diffraction study. Phys. Earth Planet
Interiors, 162, 119.
268.
Chesnut, G.N., N. Velisavljevic, and L. Sanchez. (2007) Static high
pressure x-ray diffractin of Ti-6A14V, In M. Elert, M.D. Furnish, R.
Chau, N.C. Holmes, and J. Nguyen, Eds. Shock Compression of Cond.
Matt.-2007, p. 27. (AIP, New York), Conf. Proc. of APS topical group
on SCCM, Kohala Coast, HI.
267. Crowhurst, J.C., A. Goncharov, B. Sadigh, J. Zaug, Y. Meng, and V.
Prakapenka. (2007) Synthesis and characterization of nitrides of iridium
and palladium. Mater. Res. Soc. Symp. Proc., 987, p. 0987.
266.
Cunningham, N.C., W. Qiu, K.M. Hope, H.-P. Liermann, and Y.K. Vohra.
(2007) Symmetry lowering under high pressure: Structural evidence for
f-shell delocalization in heavy rare earth metal terbium. Phys Rev.
B., 76, 212101.
265. Degtyareva, O., M.M. Canales, A. Bergara, X.-J. Chen, Yang Song,
V.V. Struzhkin, H.K. Mao, and R.J. Hemley. (2007) Crystal structure of
SiH4 at high pressure. Phys. Rev. B, 76,
064123.
264. Degtyareva, O., E.R. Hernández, J. Serrano, M. Somayazulu, H.K.
Mao, E. Gregoryanz, and R.J. Hemley. (2007) Vibrational dynamics and
stability of the high-pressure chain and ring phases in S and Se. J.
Chem. Phys., 126, 084503.
263. Ding, Y., R. Ahuja, J. Shu, P. Chow, W. Luo, and H.K. Mao. (2007)
Structural phase transition of vanadium at 69 GPa. Phys. Rev. Lett.,
98, 085502.
262.
Emmons, E.D. (2007) Vibrational Spectroscopy of Polymers at High
Pressure. Physics. University of Nevada, Reno.
261. Errandonea, D. (2007) Landau theory applied to phase transitions
in calcium orthotungstate and isostructural compounds. Europhys. Lett.,
77, 56001.
260. Evans, W.J., C.-S. Yoo, G.W. Lee, H. Cynn, M.J. Lipp, and K.
Visbeck. (2007) Dynamic diamond anvil cell (dDAC): A novel device for
studying the dynamic-pressure properties of materials. Rev. Sci.
Instrum., 78, 073904.
259. Fei, Y., A. Ricolleau, M. Frank, K. Mibe, G. Shen, and V.
Prakapenka. (2007) Toward an internally consistent pressure scale.
Proc. Nat. Acad. Sci., 104, 9182.
258. Fei, Y., L. Zhang, A. Corgne, H. Watson, A. Ricolleau, Y. Meng,
and V. Prakapenka. (2007) Spin transition and equations of state of (Mg,
Fe)O solid solutions. Geophysical Research Letters, 34,
L17307.
257. Feng, Y., R. Jaramillo, G. Srajer, J.C. Lang, Z. Islam, M.S.
Somayazulu, O.G. Shpyrko, J.J. Pluth, H.K. Mao, E.D. Isaacs, G. Aeppli,
and T.F. Rosenbaum. (2007) Pressure-tuned spin and charge ordering in an
itinerant antiferromagnet. Phys. Rev. Lett., 99, 137201.
256.
Giefers, H., E.A. Tanis, S.P. Rudin, C. Greeff, X. Ke, C. Chen, M.F.
Nicol, M. Pravica, W. Pravica, J. Zhao, A. Alatas, M. Lerche, W.
Sturhahn, and E. Alp. (2007) Phonon density of states of metallic Sn at
high pressure. Phys. Rev. Lett., 98, 245502.
255. Giefers, H., and F. Porsch. (2007) Shear induced phase transition
in PbO under high pressure. Physica B, 400, 53.
254.
Goncharov*, A.F., S. Sinogeikin, J.C. Crowhurst, M. Ahart, D.
Lakshtanov, V. Prakapenka, J. Bass, P. Beck, S.N. Tkachev, J.M. Zaug,
and Y. Fei. (2007) Cubic boron nitride as a primary calibrant for a high
temperature pressure scale. High Pressure Res., 27, 409.
253. Goncharov, A.F., and J. Crowhurst. (2007) Proton delocalization
under extreme conditions of high pressure and temperature. Phase
Transitions, 80, 1051.
252. Goncharov, A.F., C. Sanloup, N. Goldman, J.C. Crowhurst, L.E.
Fried, N. Guignot, M. Mezouar, and Y. Meng. (2007) Probing of structure
factor of water to 57 GPa and 1500K. Mater. Res. Soc. Symp. Proc.,
987, p. 0987.
251. Gregoryanz, E., A.F. Goncharov, C. Sanloup, M. Somayazulu, H.K.
Mao, and R.J. Hemley. (2007) High P- T transformations of nitrogen to
170 GPa. J. Chem Phys, 126, 184505.
250. Hamlin, J.J., S. Deemyad, J.S. Schilling, M.K. Jacobsen, R.S.
Kumar, A.L. Cornelius, G. Cao, and J.J. Neumeier. (2007) ac
susceptibility studies of the weak itinerant ferromagnet SrRuO3
under high pressure to 34 GPa. Phys Rev. B., 76,
014432.
249. Haskel*, D., Y.C. Tseng, and J.C. Lang. (2007) Instrument for
x-ray magnetic circular dichroism measurements at high pressures.
Rev. Sci. Instrum., 78, 083904.
248.
Hemley, R.J., V.V. Struzhkin, and R.E. Cohen. (2007) Measuring
high-pressure electronic and magnetic properties. In G. Shubert, Ed.
Treatise on Geophysics, p. 293. Elsevier, Amsterdam.
247.
Hong, X., G. Shen, V.B. Prakapenka, M.L. Rivers, and S.R. Sutton. (2007)
Density measurements of noncrystalline
materials at high pressure with
diamond anvil cell. Rev. Sci. Instrum., 78, 103905.
246. Hong, X., G. Shen, V.B. Prakapenka, M. Newville, M.L. Rivers, and
S.R. Sutton. (2007) Intermediate states of GeO2 glass under
pressures up to 35 GPa. Phys. Rev. B, 75, 104201.
245. Honnell, K.G., N. Velisavljevic, C.D. Adams, P.A. Rigg, G.N. Chesnut, J.
R.M. Aiken, and J.C. Boettger. (2007) Equation of state for Ti-Beta-21S.
In M. Elert, M.D. Furnish, R. Chau, N.C. Holmes, and J. Nguyen, Eds.
Shock Compression of Cond. Matt., p. 55. (AIP, New York) Conf.
Proceedings of APS topical group on SCCM, Kohala Coast, HI.
244. Iota, V., C.-s. Yoo, J.-H. Klepeis, Z. Jenei, W. Evans, and H.
Cynn. (2007) Six-fold coordinated carbon dioxide VI. Nature Mat.,
6, 34.
243.
Jacobsen, M.K., R.S. Kumar, A.L. Cornelius, S.V. Sinogeiken, and M.F.
Nicol. (2007) High pressure x-ray diffraction studies of Bi (2-x) Sb (x)
Te (3). In M. Elert, M.D. Furnish, R. Chau, N.C. Holmes, and J. Nguyen,
Eds. Shock Compression of Cond. Matt., p. 171. (AIP, New York),
Conf. Proceedings of APS topical group *CP955*, Kohala Coast, HI.
242.
Kim, E., R. Kumar, P.F. Weck, A.L. Cornelius, M. Nicol, S.C. Vogel, J.
Zhang, M. Hartl, A.C. Stowe, L. Daemen, and Y. Zhao. (2007)
Pressure-Driven Phase Transitions in NaBH4: Theory and
Experiments. J. Phys. Chem. B Ltrs., 111, 13873.
241. Kumar, R.S., A.L. Cornelius, and M.F. Nicol. (2007) Structure of
nanocrystalline ZnO up to 85 GPa. Current Appl. Phys., 7,
135.
240. Kumar, R.S., A.L. Cornelius, M.G. Pravica, M.F. Nicol, M.Y. Hu,
and P. Chow. (2007) Bonding changes in single wall carbon nanotubes
(SWCNT) on Ti and TiH2 addition probed by X-ray Raman
scattering. Diamond Rel. Mater., 16, 1136–1139.
239. Kumar, R.S., E. Kim, O. Tschauner, and A.L. Cornelius. (2007)
Pressure-induced structural phase transition in NaAlH4.
Phys. Rev. B, 75, 174110.
238. Kumar, R.S., M.G. Pravica, A.L. Cornelius, M.F. Nicol, M.Y. Hu,
and P. Chow. (2007) X-ray Raman scattering studies on C60
fullerenes and multi-walled carbon nanotubes under pressure. Diamond
Rel. Mater., 16, 1250.
237. Kumar, R.S., A. Cornelius, and M. Nicol. (2006) Equation of state
of nanocrystalline BaTiO3 up to 52 GPa at room temperature.
Phys. Stat. Sol. B, 244, 290.
236. Kumar, R.S., A.L. Cornelius, M. Somayazulu, D. Errandonea, M.F.
Nicol, and J. Gardner. (2006) High pressure structure of Tb2Ti2O7
pyrochlore at cryogenic temperatures. Phys. Stat. Sol. B, 244,
266.
235. Lakshtanov*, D.L., K.D. Litasov, S.V. Sinogeikin, H. Hellwig, J.
Li, E. Ohtani, and J.D. Bass. (2007) Effect of Al3+ and H+
on the elastic properties of stishovite. Am. Mineral., \92,
1026.
234. Lakshtanov, D.L., S. Sinogeikin, K.D. Litasov, V.B. Prakapenka, H.
Hellwig, J. Wang, C. Sanches-Valle, J.-P. Perrillat, B. Chen, M.
Somayazulu, J. Li, E. Ohtani, and J.D. Bass. (2007) The post-stishovite
phase transition in hydrous alumina-bearing Si02 in the lower
mantle of the earth. Proc. Nat. Aca. Sci., 104, 13588.
233. Larson*, B.C., A. El-Azub, W. Yang, J.Z. Tischler, W. Liu, and
G.E. Ice. (2007) Experimental characterization of the mesosocale
dislocation density tensor. Phil. Mag., 87, 1327.
232. Lazicki, A. (2007) Experimental and theoretical investigation of
the properties of low-z lithium-containing compounds at high pressure.
University of California, Davis.
231. Lee, S.K., P.J. Eng, H.K. Mao, Y. Meng, and J. Shu. (2007)
Structure of alkali borate glasses at high pressure: B and Li K-edge
inelastic x-ray scattering study. Phys. Rev. Lett., 98,
105502.
230. Liermann, H.P., A.K. Singh, M. Somayazulu, and S.K. Saxena. (2007)
Compression behavior of NbC under nonhydrostatic conditions to 57 GPa.
Elesevier, 25, 386.
229.
Lin, J.-F. (2007) Electronic spin transition of iron in the Earth's deep
mantle. Eos T. Am. Geophys. Union, 88, 13.
228. Lin, J.-F., H. Fukui, D. Prendergast, T. Okuchi, Y.Q. Cai, N.
Hiraoka, C.-S. Yoo, A. Trave, P. Eng, M.Y. Hu, and P. Chow. (2007)
Electronic bonding transition in compressed SiO2 glass.
Phys. Rev. B, 75, 012201.
227. Lin, J.-F., V.V. Struzhkin, A.G. Gavriliuk, and I. Lyubutin.
(2007) Comment on “Spin crossover in (Mg,Fe)O: A Mössbauer effect study
with an alternative interpretation of x-ray emission spectroscopy data”.
Phys. Rev. B, 75, 177102.
226. Lin, J.-F., G. Vankó, S.D. Jacobsen, V. Iota, V.V. Struzhkin, V.B.
Prakapenka, A. Kuznetsov, and C.-S. Yoo. (2007) Spin transition zone in
Earth’s lower mantle. Science, 317, 1740.
225. Lipp, M.J., J.P. Klepeis, B.J. Baer, H. Cynn, W.J. Evans, V. Iota,
and C.-S. Yoo. (2007) Transformation of molecular nitrogen to
nonmolecular phases at megabar pressures by direct laser heating.
Phys Rev. B., 76, 014113.
224. López-Solano, J., P. Rodríguez-Hernández, S. Radescu, A. Mujica,
A. Muñoz, D. Errandonea, F.J. Manjón, J. Pellicer-Porres, N. Garro, A.
Segura, C. Ferrer-Roca, R.S. Kumar, O. Tschauner, and G. Aquilanti.
(2007) Crystal stability and pressure-induced phase transitions in
scheelite AWO4 (A = Ca, Sr, Ba, Pb, Eu) binary oxides. I: A
review of recent ab initio calculations, ADXRD, XANES, and Raman
studies. Phys. Stat. Sol. B, 244, 325.
223. Lucas, M.S., A. Papandrew, and B. Fultz. (2007) Partial phonon
densities of states of 57Fe in Fe-Cr: Analysis by a
local-order cluster expansion. Phys. Rev. B, 75, 054307.
222. Luo, W., R. Ahuja, Y. Ding, and H.K. Mao. (2007) Unusual lattice
dynamics of vanadium under high pressure. Proc. Nat. Aca. Sc.,
104, 16428.
221. Manjón, F.J., D. Errandonea, J. López-Solano, P.
Rodríguez-Hernández, S. Radescu, A. Mujica, A. Muñoz, N. Garro, J.
Pellicer-Porres, A. Segura, C. Ferrer-Roca, R.S. Kumar, O. Tschauner,
and G. Aquilanti. (2007) Crystal stability and pressure-induced phase
transitions in scheelite AWO4 (A = Ca, Sr, Ba, Pb, Eu) binary
oxides. II: Towards a systematic understanding. Phys. Stat. Sol. B,
244, 295.
220.
Mao, H.K., and R.J. Hemley. (2007) The high-pressure dimension in earth
and planetary science. Proc. Nat. Aca. Sc., 104, 9114.
219.
Mao, H.K., and W.L. Mao. (2007) Diamond-anvil cells and probes for high
P-T mineral physics. In G.D. Price, Ed. Treatise on Geophysics,
p. 231. Elsevier, Amsterdam.
218. Mao, W.L., C.A. Koh, and E.D. Sloan. (2007) Clathrate hydrates
under pressure. Physics Today,October, 42.
217. Merkel, S., A.K. McNamara, A. Kubo, S. Speziale, L. Miyagi, Y.
Meng, T.S. Duffy, and H.-R. Wenk. (2007) Deformation of (Mg,Fe)SiO3
post-perovskite and D" anisotropy. Science, 316, 1729.
216. Murakami*, M., S.V. Sinogeikin, H. Hellwig, J.D. Bass, and J. Li.
(2007) Sound velocity of MgSiO3 perovskite to Mbar pressure.
Earth Planet. Sci. Lett., 256, 47–54.
215.
Pravica, M., Z. Quine, E. Romano, S. Bajar, B. Yulga, W. Yang, and D.
Hooks. (2007) Anisotropic decomposition of energetic materials. In M.
Elert, M.D. Furnish, R. Chau, N.C. Holmes, and J. Nguyen, Eds. Shock
Compression of Cond. Matt.-2007, p. 1117. (AIP, New York), Conf.
Proc. of APS topical group on SCCM, Kohala Coast, HI.
214. Pravica, M., O. Grubor-Urosevic, M. Hu, P. Chow, B. Yulga, and P.
Liermann. (2007) X-ray raman spectroscopic study of benzene at high
pressure. J. Phys. Chem. B, 111, 11635.
213. Pravica, M., Y. Shen, Z. Quine, E. Romano, and D. Hartnett. (2007)
High-Pressure Studies of Cyclohexane to 40 GPa. J. Phys. Chem. B,
111, 4103.
212. Scott, H.P., S. Huggins, M.R. Frank, S.J. Maglio, C.D. Martin, Y.
Meng, J. Santillan, and Q. Williams. (2007) Equation of state and
high-pressure stability of Fe3P-schreibersite: Implications
for phosphorus storage in planetary cores. Geophy. Res. Lett.,
34, L06302.
211. Shen, G., H.-P. Liermann, S. Sinogeikin, W. Yang, X. Hong, C.-S.
Yoo, and H. Cynn. (2007) Distinct thermal behavior of GeO2
glass in tetrahedral, intermediate, and octahedral forms. Proc. Nat.
Acad. Sci., 104, 14576–14579.
210. Shen, Y.R., R.S. Kumar, A.L. Cornelius, and M.F. Nicol. (2007)
High-pressure structural studies of dysprosium using angle-dispersive
x-ray diffraction. Phys. Rev. B, 75, 064109.
209. Sheng, H.W., H.Z. Liu, Y.Q. Cheng, J. Wen, P.L. Lee, W.K. Luo,
S.D. Shastri, and E. Ma. (2007) Polyamorphism in a metallic glass.
Nature Mat., 6, 192.
208.
Shu, J., W.L. Mao, R.J. Hemley, and H.K. Mao. (2007) Pressure-induced
distortive phase transition in chromite-spinel at 29 GPa. In M.R. Manaa,
A.F. Goncharov, R.J. Hemley, and R. Bini, Eds. Materials Research at
High Pressure, p. 179. Materials Research Society, Warrendale,
Pennsylvania.
207. Singh, A.K., H.-P. Liermann, Y. Akahama, and H. Kawamura. (2007)
Aluminum as a pressure-transmitting medium cum pressure standard for
x-ray diffraction experiments to 200 GPa with diamond anvil cells. J.
Appl. Phys., 101, 123526.
206.
Speziale, S., V.E. Lee, S.M. Clark, J.F. Lin, M.P. Pasternak, and R.
Jeanloz. (2007) Effects of Fe spin transition on the elasticity of (Mg,Fe)O
magnesiowustites and implications for the seismological properties of
the Earth's lower mantle. J. Geophys. Res., 112, B10212.
205. Tseng*, Y.C., D. Haskel, J.C. Lang, S. Sinogeikin, Y. Mudryk, V.K.
Pecharsky, and J. K. A. Gschneidner. (2007) Effect of hydrostatic
pressure upon the magnetic transitions in the Gd5(SixGe1-x)4
giant magnetocaloric compounds: X-ray magnetic circular dichroism study.
Phys. Rev. B, 76, 014411.
204. Vaitheeswaran, G., V. Kanchana, R.S. Kumar, A.L. Cornelius, M.F.
Nicol, A. Svane, A. Delin, and B. Johansson. (2007) High-pressure
structural, elastic, and electronic properties of the scintillator host
material KMgF3. Phys Rev. B., 76, 01407.
203.
Velisavljevic, N., and G.N. Chesnut. (2007) Direct hpc → bcc structural
phase transition observed in titanium alloy at high pressure. Appl.
Phys. Lett., 91, 101906.
202. Zeng, Q.S., Y.C. Li, C.M. Feng, P. Liermann, M. Somayazulu, G.Y.
Shen, H.K. Mao, R. Yang, J. Liu, T.D. Hu, and J.Z. Jiang. (2007)
Anomalous compression behavior in lanthanum/cerium-based metallic glass
under high pressure. Proc. Nat. Aca. Sci., 104,
13565–13568.
201.
Amulele, G.M., and M.H. Manghnani. (2006) Application of radial x-ray
diffraction to determine the hydrostatic equation of state and strength
of TiB2 up to 60 GPa. J. Appl. Phys., 99,
023522.
200. Cai, Y.Q., P.C. Chow, O.D. Restrepo, Y. Takano, K. Togano, H. Kito,
H. Ishii, C.C. Chen, K.S. Liang, C.T. Chen, S. Tsuda, S. Shin, C.C. Kao,
W. Ku, and A.G. Eguiluz. (2006) Low-energy charge-density excitations in
MgB2: Striking interplay between single-particle and collective behavior
for large momenta. Phys. Rev. Lett., 97, 176402.
199. Chesnut, G.N., D. Schiferal, B.D. Streetman, and W.W. Anderson.
(2006) Diamond-anvil cell for radial x-ray diffraction. J. Phys.
Condens. Matter, 18, S1083.
198. Crowhurst, J.C., A.F. Goncharov, B. Sadigh, C.L. Evans, P.G.
Morrall, J.L. Ferreira, and A.J. Nelson. (2006) Synthesis and
characterization of the nitrides of platinum and iridium. Science,
311, 1275.
197. Degtyareva, V.F., O. Degtyareva, H.-k. Mao, and R.J. Hemley.
(2006) High-pressure behavior of CdSb: Compound decomposition, phase
formation, and amorphization. Phys. Rev. B, 73, 214108.
196. Degtyareva, V.F., O. Degtyareva, M.K. Sakharov, N.I.
Novokhatskaya, P. Dera, H.K. Mao, and R.J. Hemley. (2006) Stability of
Hume-Rothery phases in Cu–Zn alloys at pressures up to 50 GPa.
Metallurgical and Mat. Trans. A, 37A, 3381.
195. Ding, Y., P. Chow, and H.-K. Mao. (2006) Determining thermal
diffuse scattering of vanadium with x-ray transmission scattering.
App. Phys. Lett., 88, 061903.
194. Ding, Y., Y. Ren, P. Chow, J. Zhang, S.C. Vogel, B. Winkler, J.
Xu, Y. Zhao, and H.K. Mao. (2006) Pressure-induced long-range magnetic
ordering in cobalt oxide. Phys. Rev. B, 74, 144101.
193. Errandonea, D. (2006) Phase behavior of metals at very high P-T
conditions: A review of recent experimental studies. J. Phys. Chem.
Solid, 67, 2017.
192. Errandonea, D., J. Pellicer-Porres, F.J. Manjon, A. Segura, C.
Ferrer-Roca, R.S. Kumar, O. Tschauner, J. Lopez-Solano, P.
Rodriguez-Hernandez, S. Radescu, A. Mujica, A. Munoz, and G. Aquilanti.
(2006) Determination of the high-pressure crystal structure of BaWO4
and PbWO4. Phys. Rev. B, 73, 224103.
191. Evans, W.J., M.J. Lipp, C.-S. Yoo, H. Cynn, J.L. Herberg, R. S.
Maxwell, and M.F. Nicol. (2006) Pressure-induced polymerization of
carbon monoxide: Disproportionation and synthesis of an energetic
lactonic polymer. Chem. Mater., 18, 2520.
190. Frank*, M.R., C.E. Runge, H.P. Scott, S.J. Maglio, J. Olson, V.
Prakapenka, and G. Shen. (2006) Experimental study of the NaCl-H2O
system up to 28 GPa: Implications for ice-rich planetary bodies.
Phys. Earth Planet. Interiors, 155, 152
189. Gavriliuk, A.G., V. Struzhkin, I.S. Lyubutin, M.I. Eremets, I.A.
Trojan, and V.V. Artemov. (2006) Equation of state and high pressure
irreversible amorphization in Y3Fe5O12.
Pisma Zh ETF, 83.
188. Giefers*, H., S. Koval, G. Wortmann, W. Sturhahn, E.E. Alp, and
M.Y. Hu. (2006) Phonon density of states of Sn in textured SnO under
high pressure: Comparison of nuclear inelastic x-ray scattering spectra
to a shell model. Phys. Rev. B, 74, 094303.
187. Giefers, H., and M. Nicol. (2006) High pressure X-ray diffraction
study of all Fe-Sn intermetallic compounds and one Fe-Sn solid solution.
J. Alloy. Compound., 422, 132.
186. Giefers, H., and M. Nicol. (2006) Equations of state of several
iron-tin intermetallic compounds. J. Phys. Chem. Solid, 67,
2027.
185. Giefers, H., M. Pravica, H.P. Liermann, and W. Yang. (2006)
Radiation-induced decomposition of PETN and TATB under pressure.
Chem. Phys. Lett., 429, 304.
184. Goncharov, A.F., V.V. Struzhkin, and S.D. Jacobsen. (2006) Reduced
radiative conductivity of low spin (Mg,Fe)O in the lower mantle.
Science, 312, 1205.
183. Gregoryanz, E., C. Sanloup, R. Bini, J. Kreutz, H.J. Jodl, M.
Somayazulu, H.K. Mao, and R.J. Hemley. (2006) On the - transition of
nitrogen. J. Chem. Phys., 124, 116102.
182. Gregoryanz, E., C. Sanloup, R. Bini, J. Kreutz, H.J. Jodl, M.
Somayazulu, H.-k. Mao, and R.J. Hemley. (2006) On the epsilon-zeta
transition of nitrogen. J. Chem. Phys., 124, 116102.
181. Hu*, J.Z., H.K. Mao, J.F. Shu, Q.Z. Guo, and H.Z. Liu. (2006)
Diamond anvil cell radial x-ray diffraction program at the National
Synchrotron Light Source. J. Phys.: Condens. Matter, 18,
S1091–S1096.
180. Iota, V., C.-S. Yoo, J.-H. Klepeis, Z. Jenei, W. Evans, and H.
Cynn. (2006) Six-fold coordinated carbon dioxide VI. Nature Materials
Letters, 6, 34.
179. Kumar, R.S., A.L. Cornelius, M.F. Nicol, K.C. Kam, A.K. Cheetham,
and J.S. Gardner. (2006) Pressure-induced structural transitions in Tb-pyrochlore
oxides. Appl. Phys. Lett., 88, 031903.
178. Kumar, R.S., A.L. Cornelius, M. Somayazulu, D. Errandonea, M.F.
266.
177. Kumar, R.S., D. Prabhakaran, A. Boothroyd, M.F. Nicol, and A.
Cornelius. (2006) High-pressure structure of LaSr2Mn2O7
bilayer manganite. J. Phys. Chem. Solid, 67, 2046.
176. Lazicki, A., C.-S. Yoo, W.J. Evans, and W.E. Pickett. (2006)
Pressure-induced antifluorite-to-anticotunnite phase transition in
lithium oxide. Phys. Rev. B, 73, 184120.
175. Levine*, L.E., B.C. Larson, W. Yang, M.E. Kassner, J.Z. Tischler,
M.A. Delos-Reyes, R.J. Fields, and W. Liu. (2006) X-ray microbeam
measurements of individual dislocation cell elastic strains in deformed
single-crystal copper. Nature Mat., 5, 619.
174. Li*, J., W. Sturhahn, J.M. Jackson, V.V. Struzhkin, J.F. Lin, J.
Zhao, H.K. Mao, and G. Shen. (2006) Pressure effect on the electronic
structure of iron in (Mg,Fe)(Si,Al)O3 perovskite: a combined
synchrotron Mössbauer and X-ray emission spectroscopy study up to 100
GPa. Phys. Chem. Miner., 33, DOI 10.1007/s00269.
173. Liermann*, H.P., R.T. Downs, and H. Yang. (2006) Site disorder
revealed through raman spectra from oriented single crystals: A case
study on karooite (MgTi2O5). Am. Mineral.,
91, 790.
172. Lin, J.F., S.D. Jacobsen, W. Sturhahn, J.M. Jackson, J. Zhao, and
C.S. Yoo. (2006) Sound velocities of ferropericlase in the Earth's lower
mantle. Geophy. Res. Lett., 33, L22304.
171. Lin, J.-F., A.G. Gavriliuk, V.V. Struzhkin, S.D. Jacobsen, W.
Sturhahn, M.Y. Hu, P. Chow, and C.-S. Yoo. (2006) Pressure-induced
electronic spin transition of iron in magnesiowustite-(Mg,Fe)O. Phys.
Rev. B, 73, 113107.
170. Lipinska-Kalita, K.E., P. Kalita, R.J. Hemley, and C.L. Gobin.
(2006) High pressure-Induced phase transition in beta-Ga203: in situ
synchrotron X-ray diffraction studies up to 70 Gpa. In A.P. Society, Ed.
APS March Meeting, Baltimore, MD.
169. Lipinska-Kalita, K.E., M. Pravica, G. Mariotto, P.E. Kalita, and
Y. Ohki. (2006) Core/shell ZrTiO4/LiAlSi2O6
nanocrystals: A synchrotron X-ray diffraction study of high-pressure
compression. J. Phys. Chem. Solid, 67, 2072.
168. Liu, H., J.S. Tse, and H.K. Mao. (2006) Stability of rocksalt
phase of zinc oxide under strong compression: Synchrotron x-ray
diffraction experiments and first-principles calculation studies. J.
Appl. Phys., 100, 093509.
167. Liu*, H., H.-R. Wenk, T.S. Duffy, and g. editors. (2006)
Special Issue on rheology and elasticity studies at ultra-high pressures
and temperatures. J. Phys. Condens. Matter, 18. 172 p.
166. Liu, H.Z., H.R. Wenk, and T.S. Duffy. (2006) Rheology and
Elasticity Studies at Ultra-High Pressures and Temperatures - Preface.
J. Phys.-Conden. Matter, 18.
165. Lyubutin, I.S., A.G. Gavriliuk, V.V. Struzhkin, S.G. Ovchinnikov,
S.A. Kharlamova, L.N. Bezmaternykh, M. Hu, and P. Chow. (2006)
Pressure-induced electron spin transition in the paramagnetic phase of
the GdFe3(BO3)4 Heisenberg magnet.
JETP Lett., 84, 518.
164. Maddox, B. (2006) Pressure-induced electronic phase transitions in
transition metal oxides and rare earth metals. University of California,
Davis.
163. Maddox, B.R., A. Lazicki, C.-S. Yoo, V. Iota, M. Chen, A.K.
McMahan, M.Y. Hu, P. Chow, R.T. Scalettar, and W.E. Pickett. (2006) 4f
delocalization in Gd: Inelastic x-ray scattering at ultrahigh pressure.
Phys. Rev. Lett., 96, 215701.
162. Maddox, B.R., C.-S. Yoo, D. Kasinathan, W.E. Pickett, and R.T.
Scalettar. (2006) High-pressure structure of half-metallic CrO2.
Phys. Rev. B, 73, 144111.
161. Manoun, B., R.P. Gulve, S.K. Saxena, S. Gupta, M.W. Barsoum, and
C.S. Zha. (2006) Compression behavior of M2AlC (M=Ti, V, Cr,
Nb, and Ta) phases to above 50 GPa. Phys. Rev. B, 73,
024110.
160. Manoun, B., S.K. Saxena, T. El-Raghy, and M.W. Barsoum. (2006)
High-pressure x-ray diffraction study of Ta4AlC3.
Appl. Phys. Lett., 88, 201902.
159. Mao, H.K., J. Badro, J. Shu, R.J. Hemley, and A.K. Singh. (2006)
Strength, anisotropy, and preferred orientation of solid argon at high
pressures. J. Phys.: Condens. Matter, 18, S963–S968.
158. Mao, W., A.J. Campbell, D.L. Heinz, and G. Shen. (2006) Phase
relations of Fe-Ni alloys at high pressure and temperature. Phys.
Earth Planet. Interiors, 155, 146.
157. Mao, W.L., and H.K. Mao. (2006) Ultrahigh-pressure experiment with
a motor-driven diamond anvil cell. J. Phys.: Condens. Matter,
18, S1069–S1073.
156. Mao, W.L., H.K. Mao, Y. Meng, P. Eng, M.Y. Hu, P. Chow, Y.Q. Cai,
J. Shu, and R.J. Hemley. (2006) X-ray-induced dissociation of H2O
and formation of an O2-H2 alloy at high pressure.
Science, 314, 636.
155. Mao, W.L., H.K. Mao, W. Sturhahn, J. Zhao, V.B. Prakapenka, Y.
Meng, J. Shu, Y. Fei, and R.J. Hemley. (2006) Iron-rich post-perovskite
and the origin of ultralow-velocity zones. Science, 312,
564.
154. Martin, C.D., W.A. Crichton, H. Liu, V. Prakapenka, J. Chen, and
J.B. Parise. (2006) Rietveld structure refi nement of perovskite and
post-perovskite phases of NaMgF3 (Neighborite) at high
pressures. Am. Mineral., 91, 1703.
153. Martin, C.D., W.A. Crichton, H. Liu, V. Prakapenka, J. Chen, and
J.B. Parise. (2006) Phase transitions and compressibility of NaMgF3
(Neighborite) in perovskite- and post-perovskite-related structures.
Geophys. Res. Lett., 33, L11305.
152. Maunon, B., S.K. Saxena, T. El-Raghy, and M.W. Barsoum. (2006)
High-pressure x-ray diffraction study of Ta4AIC3.
151. Meng, Y., G. Shen, and H.K. Mao. (2006) Double-sided laser heating
system at HPCAT for in situ x-ray diffraction at high pressures
and high temperatures. J. Phys.: Condens. Matter, 18,
S1097–S1103.
150. Meng, Y., R.B. von Dreele, B.H. Toby, P. Chow, M.Y. Hu, G. Shen,
and H.K. Mao. (2006) Hard x-ray radiation induced dissociation of N2
and O2 molecules and the formation of ionic nitrogen oxide
phases under pressure. Phys. Rev. B, 74, 214107.
149. Merkel, S., A. Kubo, L. Miyagi, S. Speziale, T.S. Duffy, H.K. Mao,
and H.-R. Wenk. (2006) Plastic deformation of MgGeO3 post-perovskite
at lower mantle pressures. Science, 311, 644.
148. Ming, L.C., P. Zinin, Y. Meng, X.R. Liu, S.M. Hong, and Y. Xie.
(2006) A cubic phase of C3N4 synthesized in the
diamond-anvil cell. J. Appl. Phys., 99, 033520.
147. Papandrew, A.B., M.S. Lucas, R. Stevens, I. Halevy, B. Fultz, M.Y.
Hu, P. Chow, R.E. Cohen, and M. Somayazulu. (2006) Absence of magnetism
in hcp iron-nickel at 11 K. Phys. Rev. Lett., 97, 087202.
146. Pravica, M., K. Lipinska-Kalita, Z. Quine, E. Romano, Y. Shen, M.F.
Nicol, and W.J. Pravica. (2006) Studies of phase transitions in PETN at
high pressures. J. Phys. Chem. Solid, 67, 2159.
145. Pravica, M., Z. Quine, and E. Romano. (2006) X-ray diffraction
study of elemental thulium at pressures up to 86 GPa. Phys. Rev. B,
89, 104107.
144. Raju, S.V., S.R. Kulkarni, S.K. Saxena, H.P. Liermann, and S.V.
Sinogeikin. (2006) Compression behavior of nanosized nickel and
molybdenum. Appl. Phys. Lett., 89, 261901.
143. Rodriguez-Hernandez, P., J. López-Solano, S. Radescu, A. Mujica,
A. Muñoz, D. Errandonea, J. Pellicer-Porres, A. Segura, C. Ferrer-Roca,
and F.J. Manjón. (2006) Theoretical and experimental study of CaWO4
and SrWO4 under pressure. J. Phys. Chem. Solid, 67,
2164.
142. Runge, C.E., A. Kubo, B. Kiefer, Y. Meng, V.B. Prakapenka, G.
Shen, R.J. Cava, and T.S. Duffy. (2006) Equation of state of MgGeO3
perovskite to 65Â GPa: comparison with the post-perovskite phase.
Phys. Chem. Miner., 33, 699.
141. Santillán*, J., S.H. Shim, G.Y. Shen, and V.B. Prakapenka. (2006)
High-pressure phase transition in Mn2O3:
Application for the crystal structure and preferred orientation of the
CaIrO3 type. Geophys. Res. Lett., 33,
doi:10.1029/2006GL026423.
140. Seagle, C.T., A.J. Campbell, D.L. Heinz, G. Shen, and V.B.
Prakapenka. (2006) Thermal equation of state of Fe3S and
implications for sulfur in Earth’s core. J. Geophys. Res., 111,
B06209.
139. Sheng, H.W., E. Ma, H.Z. Liu, and J. Wen. (2006) Pressure tunes
atomic packing in metallic glass. Appl. Phys. Lett., 88,
171906.
138. Shieh*, S.R., T.S. Duffy, A. Kubo, G. Shen, V.B. Prakapenka, N.
Sata, K. Hirose, and Y. Ohishi. (2006) Equation of state of the
postperovskite phase synthesized from a natural (Mg,Fe)SiO3
orthopyroxene. Proc. Nat. Acad. Sci., 103, 3039–3043.
137. Shieh*, S.R., A. Kubo, T.S. Duffy, V. Prakapenka, and G. Shen.
(2006) High-pressure phases in SnO2 to 117 GPa. Phys. Rev.
B, 73, 014105.
136. Singh, A.K., A. Jain, H.P. Liermann, and S.K. Saxena. (2006)
Strength of iron under pressure up to 55 GPa from X-ray Diffraction
line-width analysis. J. Phys. Chem. Solids, 67, 2197.
135. Singh, A.K., H.P. Liermann, S.K. Saxena, H.K. Mao, and S.U. Devi.
(2006) Nonhydrostatic compression of gold powder to 60 GPa in a diamond
anvil cell: estimation of compressive strength from x-ray diffraction
data. J. Phys.: Condens. Matter, 18, S969–S978.
134. Sinogeikin*, S., J. Bass, V. Prakapenka, D. Lakshtanov, G. Shen,
C. Sanchez-Valle, and M. Rivers. (2006) Brillouin spectrometer
interfaced with synchrotron radiation for simultaneous x-ray density and
acoustic velocity measurements. Rev. Sci. Instrum., 77,
103905.
133. Speziale, S., I. Lonardelli, L. Miyagi, J. Pehl, C.E. Tommaseo,
and H.-R. Wenk. (2006) Deformation experiments in the diamond-anvil
cell: Texture in copper to 30 GPa. J. Phys. Cond. Matt., 18,
S1007.
132. Struzhkin, V.V., H.K. Mao, J.-F. Lin, R.J. Hemley, J.S. Tse, Y.
Ma, M.Y. Hu, P. Chow, and C.-C. Kao. (2006) Valence band x-ray emission
spectra of compressed germanium. Phys. Rev. Lett., 96,
137402.
131. Swamy*, V., A. Kuznetsov, L.S. Dubrovinsky, P.F. McMillan, V.B.
Prakapenka, G. Shen, and B.C. Muddle. (2006) Size-dependent
pressure-induced amorphization in nanoscale TiO2. Phys.
Rev. Lett., 96, 135702.
130. Tommaseo, C., J. Devine, S. Merkel, S. Speziale, and H.-R. Wenk.
(2006) Texture development and elastic stresses in magnesiowüstite at
high pressure. Phys. Chem. Miner., 33, 84.
129. Tschauner, O., D. Errandonea, and G. Serghiou. (2006) Possible
superlattice formation in high-temperature treated carbonaceous MgB2
at elevated pressur. Physica B, 371, 88.
128. Tschauner, O., S.-N. Luo, P.D. Asimow, and T.J. Ahrens. (2006)
Recovery of stishovite-structure at ambient conditions out of
shock-generated amorphous silica. Am. Mineral., 91, 1857.
127. Wenk, H.-R., I. Lonardelli, S. Merkel, L. Miyagi, J. Pehl, S.
Speziale, and C.E. Tommaseo. (2006) Deformation textures produced in
diamond anvil experiments, analysed in radial diffraction geometry.
J. Phys. Condens. Matter, 18, S933.
126. Winell, S., H. Annersten, and V. Prakapenka. (2006) The
high-pressure phase transformatin and breakdown of MgFe2O4.
Am. Mineral., 91, 560.
125. Yoshimura, Y., S.T. Stewart, Maddury Somayazulu, H.K. Mao, and
R.J. Hemley. (2006) High-pressure x-ray diffraction and Raman
spectroscopy of ice VIII. J. Chem. Phys., 124, 024502.
124. Young, A.F., C. Sanloup, E. Gregoryanz, S. Scandolo, R.J. Hemley,
and H.K. Mao. (2006) Synthesis of novel transition metal nitrides IrN2
and OsN2. Phys. Rev. Lett., 96, 155501.
123. Zinin, P.V., L.C. Ming, I. Kudryashov, N. Konishi, M.H. Manghnani,
and S.K. Sharma. (2006) Pressure- and temperature-induced phase
transition in the B–C system. J. Appl. Phys., 100, 013516.
122. Ahart, M., R.E. Cohen, V. Struzhkin, E. Gregoryanz, D. Rytz, S.A.
Prosandeev, H.K. Mao, and R.J. Hemley. (2005) High-pressure Raman
scattering and x-ray diffraction of the relaxor ferroelectric 0.9Pb(Zn1/3Nb2/3)O3-0.04PbTiO3.
Phys. Rev. B, 71, 144102.
121. Amulele, G.M., and M.H. Manghnani. (2005) Compression studies of
TiB2 using synchrotron x-ray diffraction and ultrasonic
techniques. J. Appl. Phys., 97, 023506.
120. Cai, Y.Q., H.K. Mao, P.C. Chow, J.S. Tse, Y. Ma, S. Patchkovskii,
J.F. Shu, V. Struzhkin, R.J. Hemley, H. Ishii, C.C. Chen, I. Jarrige,
C.T. Chen, S.R. Shieh, E.P. Huang, and C.C. Kao. (2005) Ordering of
hydrogen bonds in high-pressure low-temperature H2O. Phys.
Rev. Lett., 94, 025502.
119. Chen*, J., H. Liu, C.D. Martin, J.B. Parise, and D.J. Weidner.
(2005) Crystal chemistry of NaMgF3 perovskite at high
pressure and temperature. Am. Mineral., 90, 1534.
118. Chen, X.-J., V.V. Struzhkin, Z. Wu, M. Somayazulu, J. Qian, S.
Kung, A.N. Christensen, Y. Zhao, R.E. Cohen, H.K. Mao, and R.J. Hemley.
(2005) Hard superconducting nitrides. Proc. Nat. Acad. Sci.,
102, 3198–3201.
117. Cunningham, N.C., N. Velisavljevic, and Y.K. Vohra. (2005) Crystal
grain growth at the alpha-uranium phase transformation in praseodymium.
Phys. Rev. B, 71, 012108.
116. Degtyareva, O., E. Gregoryanz, H.K. Mao, and R.J. Hemley. (2005)
Crystal structure of S and Se up to 160 GPa. High Pressure Res.,
25, 17.
115. Degtyareva, O., E. Gregoryanz, M. Somayazulu, P. Dera, H.K. Mao,
and R.J. Hemley. (2005) Novel chain structures in group VI elements.
Nature Mat., 4, 152.
114. Degtyareva, O., E. Gregoryanz, M. Somayazulu, H.K. Mao, and R.J.
Hemley. (2005) Crystal structure of the superconducting phases of S and
Se. Phys. Rev. B, 71, 214104.
113. Degtyareva, V.F., O. Degtyareva, M.K. Sakharov, N.I.
Novokhatskaya, P. Dera, H.K. Mao, and R.J. Hemley. (2005) Stability of
Hume-Rothery phases in Cu–Zn alloys at pressures up to 50 GPa. J.
Phys.: Condens. Matter, 17, 7955.
112. Ding, Y., H. Liu, M. Somayazulu, Y. Meng, J. Xu, C.T. Prewitt,
R.J. Hemley, and H.K. Mao. (2005) Zone-axis x-ray diffraction of
single-crystal Fe1-xO under pressure. Phys. Rev. B,
72, 174109.
111. Ding, Y., H. Liu, J. Xu, C.T. Prewitt, R.J. Hemley, and H.K. Mao.
(2005) Zone-axis diffraction study of pressure induced inhomogeneity in
single-crystal Fe1-xO. Appl. Phys. Lett., 87,
041912.
110. Ding, Y., J. Xu, C.T. Prewitt, R.J. Hemley, H.K. Mao, J.A. Cowan,
J. Zhang, J. Qian, S.C. Vogel, K.A. Lokshin, and Y. Zhao. (2005)
Variable pressure-temperature neutron diffraction of wüstite Fe1-xO:
Absence of long-range magnetic order to 20 GPa. Appl. Phys. Lett.,
86, 052505.
109. Dreger, Z.A., Y.M. Gupta, C.-S. Yoo, and H. Cynn. (2005)
High-Pressure-Induced phase transitons in pentaerythritol: X-ray and
raman studies. J. Phys. Chem. B, 109, 22581.
108. Duffy, T.S. (2005) Synchrotron facilities and the study of the
earth's deep interior. Rep. Prog. Phys., 68, 1811.
107. Errandonea, D., Y. Meng, M. Somayazulu, and D. Häusermann. (2005)
Pressure-induced alpha to omega transition in titanium metal: A
systematic study of the effects of uniaxial stress. Physica B,
355, 116.
106. Errandonea, D., J. Pellicer-Porres, F.J. Manjon, A. Segura, C.
Ferrer-Roca, R.S. Kumar, O. Tschauner, P. Rodriguez-Hernandez, J.
Lopez-Solano, S. Radescu, A. Mujica, A. Munoz, and G. Aquilanti. (2005)
High-pressure structural study of the scheelite tungstates CaWO4
and SrWO4. Phys. Rev. B, 72, 174106.
105. Evans, W.J., M.J. Lipp, H. Cynn, C.S. Yoo, M. Somayazulu, D.
Hausermann, G. Shen, and V. Prakapenka. (2005) X-ray diffraction and
raman studies of beryllium: Static and elastic properties at high
pressures. Phys. Rev. B, 72, 094113.
104. Feng, Y., M.S. Somayazulu, R. Jaramillo, T.F. Rosenbaum, E.D.
Isaacs, J. Hu, and H.K. Mao. (2005) Energy dispersive x-ray diffraction
of charge density waves via chemical filtering. Rev. Sci. Instrum,
76, 063913.
103. Gavriliuk, A.G., V.V. Struzhkin, I.S. Lyubutin, M.Y. Hu, and H.K.
Mao. (2005) Phase transition with suppression of magnetism in BiFeO3 at
high pressure. JETP Lett., 82, 224.
102. Goncharov, A.F., N. Goldman, L.E. Fried, J.C. Crowhurst, I-Feng W.
Kuo, C.J. Mundy, and J.M. Zaug. (2005) Dynamic Ionization of water under
extreme conditions. Phys. Rev. Lett., 94, 125508.
101. Goncharov, A.F., M.R. Manaa, J.M. Zaug, R.H. Gee, L.E. Fried, and
W.B. Montgomery. (2005) Polymerization of formic acid under high
pressure. Phys. Rev. Lett., 94, 065505.
100. Goncharov, A.F., J. Zaug, J.C. Crowhurst, and E. Gregoryanz.
(2005) Optical calibration of pressure sensors for high pressures and
temperatures. J. Appl. Phys., 97, 094917.
99. Gregoryanz, E., O. Degtyareva, M. Somayazulu, R.J. Hemley, and H.K.
Mao. (2005) Melting of dense sodium. Phys. Rev. Lett., 94,
185502.
98. Hemley, R.J., H.K. Mao, and V.V. Struzhkin. (2005) Synchrotron
radiation and high pressure: new light on materials under extreme
conditions. J. Synch. Rad., 12, 135.
97. Hope, K. (2005) Crystallographic phases and anisotropic
compressibility in light actinide metals at high pressures. University
of Alabama, Birmingham.
96. Jackson, J.M., W. Sturhahn, G.Y. Shen, J.Y. Zhao, M.Y. Hu, D.
Errandonea, J.D. Bass, and Y. Fei. (2005) A synchrotron Mössbauer
spectroscopy study of (Mg,Fe)SiO3 perovskite up to 120 GPa.
Am. Mineral., 90, 199.
95. Kumar, R.S., and A.L. Cornelius. (2005) Structural transitions in
NaBH4 under pressure. Appl. Phys. Lett., 87,
261916.
94. Kumar, R.S., A.L. Cornelius, E. Kim, Y. Shen, S. Yoneda, C. Chen,
and M.F. Nicol. (2005) Pressure induced structural phase transition in
AgSbTe2. Phys. Rev. B, 72, 060101.
93. Kumar, R.S., A.L. Cornelius, Y. Shen, T.G. Kumary, J. Janaki, M.C.
Valsakumar, and M.F. Nicol. (2005) Structural behavior of non-oxide
perovskite superconductor MgCNi3 at pressures up to 32 GPa.
Physica B, 363, 190.
92. Kumar, R.S., H. Kohlmann, B.E. Light, A.L. Cornelius, V. Raghavan,
T.W. Darling, and J.L. Sarrao. (2005) The crystal structure of CeRhIn5
under pressure. Physica B, 359-361, 407.
91. Kumar, R.S., S. Rekhi, A.L. Cornelius, and M.W. Barsoum. (2005)
Compressibility of Nb2AsC to 41 GPa. Appl. Phys. Lett.,
86, 11904.
90. Lamelas, F.J., Z.A. Dreger, and Y.M. Gupta. (2005) Raman and x-ray
scattering studies of high-pressure phases of urea. J. Phys. Chem. B,
109, 8206.
89. Lazicki, A., B. Maddox, W.J. Evans, C.S. Yoo, A.K. McMahan, W.E.
Pickett, R.T. Scalettar, M.Y. Hu, and P. Chow. (2005) New cubic phase of
Li3N: Stability of the N3- ion to 200 GPa.
Phys. Rev. Lett., 95, 165503.
88. Lee, S.K., P.J. Eng, H.K. Mao, Y. Meng, M. Newville, M.Y. Hu, and
J. Shu. (2005) Probing of bonding changes in B2O3
glasses at high pressure with inelastic X-ray scattering. Nature Mat.,
4, 851.
87. Liermann, H.P., A.K. Singh, B. Manoun, S.K. Saxena, and C.S. Zha.
(2005) Compression behavior of TaC0.98 under nonhydrostatic
and quasi-hydrostatic pressures up to 76 GPa. Int. J. Refactory Met.
Hard Mat., 23, 109.
86. Lin, J.-F., E. Gregoryanz, V.V. Struzhkin, M. Somayazulu, H.K.
Mao, and R.J. Hemley. (2005) Melting behavior of H2O at high
pressures and temperatures. Geophys. Res. Lett., 32,
L11306.
85. Lin, J.-F., V.V. Struzhkin, S.D. Jacobsen, M.Y. Hu, P. Chow, J.
Kung, H. Liu, H.K. Mao, and R.J. Hemley. (2005) Spin transition of iron
in magnesiowüstite in the Earth’s lower mantle. Nature, 436,
377.
84. Lin, J.-F., W. Sturhahn, J. Zhao, G. Shen, H.K. Mao, and R.J.
Hemley. (2005) Sound velocities of hot dense iron: Birch’s law
revisited. Science, 308, 1892.
83. Lin, T., W. Schildkamp, K. Brister, P.C. Doerschuk, M. Somayazulu,
H.K. Mao, and J.E. Johnson. (2005) The mechanism of
high-pressure-induced ordering in a macromolecular crystal. Acta
Cryst., D61, 737–743.
82. Lipinska-Kalita, K.E., G. Mariotto, P.E. Kalita, and Y. Ohki.
(2005) Effects of high pressure on stability of the nanocrystalline
LiAlSi2O6 phase of a glass–ceramic composite: A
synchrotron X-ray diffraction study. Physica B, 365, 155.
81. Lipinska-Klita, K.E., M. Pravica, and M. Nicol. (2005)
High-pressure synchrotron radiation x-ray diffraction studies of
pentaerythritol tetranitrate C (CH2ONO24. In E.
ed. Dingus, Ed. Joint 20th AIRAPT and 43rd EHPRG International
Conference on High Pressure Science and Technology, 063.
Forschungszentrum Karlsruhe GmbH.
80. Lipp, M.J., W.J. Evans, B.J. Baer, and C.-S. Yoo. (2005)
High-energy-density extended CO solid. Nature Mat., 4,
211.
79. Liu, H., J. Chen, J. Hu, C.D. Martin, D.J. Weidner, D. Häusermann,
and H.K. Mao. (2005) Octahedral tilting evolution and phase transition
in orthorhombic NaMgF3 perovskite under pressure. Geophys.
Res. Lett., 32, L04304.
78. Liu, H., Y. Ding, M. Somayazulu, J. Qian, J. Shu, D. Häusermann,
and H.K. Mao. (2005) Rietveld refinement study of the pressure
dependence of the internal structural parameter u in the würtzite phase
of ZnO. Phys. Rev. B, 71, 212103.
77. Liu, H., J.S. Tse, J. Hu, Z. Liu, L. Wang, J. Chen, D.J. Weidner,
Y. Meng, D. Häusermann, and H.K. Mao. (2005) Structural refinement of
the high-pressure phase of aluminum trihydroxide: In-situ
high-pressure angle dispersive synchrotron x-ray diffraction and
theoretical studies. J. Phys. Chem. B, 109, 8857.
76. Luo, S.N., O. Tschauner, T.E. Tierney, I.D.C. Swift, S.J. Chipera,
and P.D. Asimow. (2005) Novel crystalline carbon-cage structure
synthesized from laser-driven shock wave loading of graphite. J.
Chem. Phys., 123, 024703.
75. Manoun, B., and S.K. Saxena. (2005) High pressure study of Ti4AlN3
to 55 GPa. Appl. Phys. Lett., 86, 101906.
74. Mao, W. (2005) Geophysics and geochemistry of iron in the earth's
core. The University of Chicago.
73. Mao, W.L., Y. Meng, G. Shen, V.B. Prakapenka, A.J. Campbell, D.L.
Heinz, J. Shu, R. Caracas, R.E. Cohen, Y. Fei, R.J. Hemley, and H.K.
Mao. (2005) Iron-rich silicates in the Earth’s D” layer. Proc. Nat.
Acad. Sci., 402, 9751.
72. Mao*, W.L., V.V. Struzhkin, H.K. Mao, and R.J. Hemley. (2005)
Pressure–temperature stability of the van der Waals compound (H2)4CH4.
Chem. Phys. Lett., 402, 66.
71. Ming, L.C., S.K. Sharma, A.J. Jayaramam, Y. Kobayashi, E. Suzuki,
S. Endo, V. Prakapenka, and Y. Ding. (2005) X-ray diffraction and raman
studies of the CuGeO3 (iii)-(iv) transformation under high
pressures. Spectrochim. Acta A, 61, 2418.
70. Orosel, D., P. Balog, H. Liu, J. Qian, and M. Jansen. (2005) Sb2O4
at high pressures and high temperatures. J. Solid State Chem.,
178, 2602.
69. Pehl, J. (2005) Quantitative rietveld texture analysis of
geological materials. University of California, Berkeley.
68. Pravica, M., K.E. Lipinska-Kalita, Z. Quine, E. Romano, and M.
Nicol. (2005) X-ray diffraction study of elemental erbium to 65GPa. In
E. Dingus, Ed. Joint 20th AIRAPT and 43rd EHPRG International
Conference on High Pressure Science and Technology.
67. Pravica, M.G., E. Romano, and Z. Quine. (2005) X-ray diffraction
study of elemental erbium to 70 GPa. Phys. Rev. B, 72,
214122.
66. Qiu, W. (2005) High-pressure high-temperature studies on Fe-Pt-Ag
nanoparticles using carbon-13 pressure sensor. University of Alabama,
Birmingham.
65. Song, Y., R.J. Hemley, H.K. Mao, and D.R. Herschbach. (2005)
Nitrogen-containing molecular systems at high presssures and
temperature. In M.R. Manaa, Ed. Chemistry at Extreme Conditions,
p. 189. Elsevier, Amsterdam.
64. Song, Y., Z. Liu, R.J. Hemley, H.K. Mao, and D.R. Herschbach.
(2005) High-pressure vibrational spectroscopy of sulfur dioxide. J.
Chem. Phys., 122, 174511.
63. Speziale, S., A. Milner, V.E. Lee, S.M. Clark, M.P. Pasternak, and
R. Jeanloz. (2005) Iron spin transition in Earth's Mantle. Proc. Nat.
Aca. Sc., 102, 17918.
62. Tschauner, O., J. McClure, and M. Nicol. (2005) Strategies for
reducing preferred orientationan and strain in powder samples for
high-pressure synchrotron x-ray diffraction in diamond anvil cells.
J. Synchrotron Rad., 12, 626.
61. Velisavljevic, N. (2005) Development of the designer diamond
anvils and study of structural and electrical properties of f-electron
metals at ultra-high pressures. University of Alabama, Birmingham.
60. Velisavljevic, N., Y.K. Vohra, and S.T. Weir. (2005) Simultaneous
electrical and x-ray diffraction studies on neodymium metal to 152 GPa.
High Pressure Res., 25, 137.
59. Wang, Z., L.L. Daemen, Y. Zhao, C.S. Zha, R.T. Downs, X. Wang, Z.L.
Wang, and R.J. Hemley. (2005) Morphology-tuned wurtzite-type ZnS
nanobelts. Nature Mat., 4, 922.
58. Yoo, C.S. (2005) High Pressure Materials Research: Novel extended
phases of molecular triatomics. In M.R. Manaa, Ed. Chemistry at
Extreme Conditions, p. 165
57. Yoo, C.S., B. Maddox, J.-H.P. Klepeis, V. Iota, W. Evans, A.
McMahan, M.Y. Hu, P. Chow, M. Somayazulu, D. Häusermann, R.T. Scalettar,
and W.E. Pickett. (2005) First-order isostructural Mott transition in
highly compressed MnO. Phys. Rev. Lett., 94, 115502.
56. Amulele,
G.M., M.H. Manghnani, B. Li, D.J.H. Errrandonea, M. Somayazulu, and Y.
Meng. (2004) High pressure ultrasonic and x-ray studies on monolithic
SiC composite. J. Appl. Phys., 95, 1806.
55. Chelazzi, D., M. Ceppatelli, M. Santoro, R. Bini, and V. Shettino.
(2004) High-pressure synthesis of crystalline polyethylene using optical
catalysis. Nat. Mater., 3, 470.
54. Chesnut, G.N., B.D. Streetman, D. Schiferl, R.S. Hixson, W.M.
Anderson, M. Nicol, and Y. Meng. (2004) Static x-ray diffraction study
of cerium: The standard approach & the magic-angle approach. Proc.
Shock Compress. Condens. Mat. (Amer. Inst. Phys., NY), 37
53. Eremets, M.I., A.G. Gavriliuk, N.R. Serebryanaya, I.A. Trojan,
D.A. Dzivenko, R. Boehler, H.K. Mao, and R.J. Hemley. (2004) Structural
transformation of molecular nitrogen to a single-bonded atomic state at
high pressures. J. Chem. Phys., 121, 11296
52. Gregoryanz, E., C. Sanloup, M. Somayazulu, J. Badro, G. Fiquet,
H.K. Mao, and R.J. Hemley. (2004) Synthesis and characterization of a
binary noble metal nitride. Nat. Mater., 3, 294.
51. Guthrie, M., C.A. Tulk, C.J. Benmore, J. Xu, J.L. Yarger, D.D.
Klug, J.S. Tse, H.K. Mao, andR.J. Hemley. (2004) Formation and structure
of a dense octahedral glass. Phys. Rev. Lett., 93, 15502.
50. Hemley, R.J. (2004) New findings in static high-pressure science.
Proc. Nat. Aca. Sc., 17
Iota, V., J.H. Park, and C.S. Yoo. (2004) Phase diagram of nitrous:
Analogy with carbon dioxide. Phys. Rev. B, 69, 064106.
49. Kumar, R., H. Kohlmann, B.E. Light, and A.L. Cornelius. (2004)
Anistropic elastic properties of CeRhIn5. Phys. Rev. B,
69, 014515.
48. Kumar, R.S., A.L. Cornelius, and J.L. Sarrao. (2004)
Compressibility of CeMIn5 and Ce2MIn8
(M=Rh, Ir, and Co) compounds. Phys. Rev. B, 70, 214256.
47. Li, J., V. Struzhkin, H.K. Mao, J. Shu, R.J. Hemley, Y. Fei, B.
Mysen, D. P., V.B. Prakapenka, and G. Shen. (2004) Electronic spin state
of iron in lowe mantle perovskite. Proc. Nat. Aca. Sci., 101,
14027.
46. Lin, J.F., O. Degtyareva, C.T. Prewitt, P. Dera, N. Sata, E.
Gregoryanz, H.K. Mao, and R.J. Hemley. (2004) Crystal structure of a
high-pressure/high-temperature phase of alumina by in situ X-ray
diffraction. Nat. Mater., 3, 389.
45. Lin, J.F., Y. Fei, W. Sturhahn, J. Zhao, H.K. Mao, and R.J.
Hemley. (2004) Magnetic transiton and sound velocities of Fe3S
at high pressure: implications for Earth and planetary cores. Earth
Planet Sc. Lett., 226, 33.
44. Lin, J.F., B. Militzer, V. Struzhkin, E. Gregoryanz, and R.J.
Hemley. (2004) High pressure-temperature Raman measurements of H2O
melting to 22 GPa and 900 K. J. Chem. Phys., 121, 8423
43. Lin, J.F., M. Santoro, V. Struzhkin, H.K. Mao, and R.J. Hemley.
(2004) In situ high pressure-temperature Raman spectroscopy technique
with laser-heated diamond anvil cells. Rev. Sci. Instrum., 75,
3302
42. Lin, J.F., V. Struzhkin, H.K. Mao, R.J. Hemley, P.C. Chow, M. Hu,
and J. Li. (2004) Magnetic transition in compressed Fe3C from
x-ray emission spectroscopy. Phys Rev. B., 70, 212405.
41. Lin, J.F., W. Sturhahn, J. Zhao, G. Shen, H.K. Mao, and R.J.
Hemley. (2004) Absolute temperature measurement in the diamond anvil
cell. Geophy. Res. Lett., 31, 020599.
40. Liu, H., J. Hu, J. Shu, D. Hausermann, and H.K. Mao. (2004) Lack
of the critical pressure for weakening of size-induced stiffness in
3C--SiC nanocrystals under hydrostatic compression. Appl. Phys. Lett.,
85, 1973.
39. Liu, H., C. Jin, J. Chen, and J. Hu. (2004) Anomalous dynamical
charge behavior of nanocrystalline 3C-SiC upon compression. J. Am.
Ceramic Soc., 87, 2291
38. Liu*, H., W. Klein, A. Sani, and M. Jansen. (2004) Pressure
induced phase transition and amorphization of Na3ONO2.
Phys. Chemm. Chem. Phys., 6, 881
37. Liu, H., H.K. Mao, M. Somayazulu, Y. Ding, Y. Meng, and D.
Häusermann. (2004) B1 to B2 phase transition of transition metal
monoxide CdO under strong compression. Phys. Rev. B, 70,
0954114.
36. Liu*, H., J. Xu, Z. Liu, J. Shu, H.K. Mao, and J. Chen. (2004)
Phase transition and compression behavior of gibbsite under high
pressure. Phys. Chem. Miner., 31, 240
35. Liu*, Z., J. Xu, H.P. Scott, Q. Williams, H.K. Mao, and R.J.
Hemley. (2004) Moissanite (SiC) as windows and anvils for high-pressured
infrared spectroscopy. Rev. Sci. Instrum., 75, 5026
34. Luo, S.-N., D.C. Swift, T.E. Tierney, D.L. Paisley, G.A. Kyrala,
R.P. Johnson, A.A. Hauer, O. Tschauner, and P.D. Asimov. (2004)
Laser-induced shock waves in condensed matter: Some techniques and
applications. High Pressure Res., 24, 409
33. Luo, S.-N., O. Tschauner, P.D. Asimow, and T.J. Ahrens. (2004) A
new dense silica polymorph: A possible link between tetrahedrally and
cotahedrally coordinated silica. Am. Mineral., 89, 455
32. Ma, Y., M. Somayazulu, G. Shen, H.K. Mao, J. Shu, and R.J. Hemley.
(2004) In situ x-ray diffraction studies of iron to Earth-core
conditions. Phys.Earth Planet. Inter., 143, 455
31. Mao, W.L. (2004) Nuclear resonant x-ray scattering of iron hydride
at high pressure. Geophy. Res. Lett.,, 31, L15618.
30. Mao, W.L., G. Shen, V.B. Prakapenka, Y. Meng, A.J. Campbell, D.L.
Heinz, J. Shu, R.J. Hemley, and H.K. Mao. (2004) Ferromagnesian
postperovskite silicates in the D' layer of the Earth. Proc. Nat. Aca.
Sc., 101, 15867.
29. Meng, Y., H.K. Mao, P. Eng, T. Trainor, M. Newville, M. Hu, C.C.
Kao, D. Häusermann, and R.J. Hemley. (2004) The formation of sp3 bonding
in compressed BN. Nature Mater., 3, 111.
28. Scott, H.P., R.J. Hemley, H.K. Mao, D.R. Herschbach, L.E. Fried,
Howard, W. Michael, and S. Bastea. (2004) Generation of methane in the
Earth's mantle: In situ high pressure-temperature measurements of
carbonate reduction. Proc. Nat. Aca. Sc., 101, 14023.
27. Senter, R.A., C. Pantea, Y. Wang, H. Liu, T.W. Zerda, and J.L.
Coffer. (2004) Structural influence of erbium centers on silicon
nanocrystal phase transitions. Phys. Rev. Lett., 93,
175502.
26. Shen, G., W. Sturhahn, E.E. Alp, J. Zhao, T.S. Toellner, V.B.
Prakapenka, Y. Meng, and H.K. Mao. (2004) Phonon density of states in
iron at high pressures and high temperatures. Phys. Chem. Miner.,
31, 353
25. Shen, Y., R.S. Kumar, M. Pravica, and M.F. Nicol. (2004)
Characteristics of silicone fluid as a pressure transmitting medium in
diamond anvil cells. Rev. Sci. Instrum., 75, 4450.
24. Signorato, R., D. Häusermann, M. Somayazulu, and J.-F. Carre.
(2004) Performance of an adaptive µ-focusing Kirkpatrick-Baez system for
high pressure studies at the Advanced Photon Source. In A.M. eds.
Khounscary, Dinger, U. & Ota, K., Ed. Proc. SPIE-Int. Soc. Opt. Eng.,
p. 112, Bellingham, WA.
23. Singh, A.K., H.P. Liermann, and S.K. Saxena. (2004) Strength of
magnesium oxide under high pressure: evidence of grain-size dependence.
Solid State Comm., 132, 795.
22. Struzhkin, V., H.K. Mao, W.L. Mao, R.J. Hemley, W. Sturhahn, E.E.
Alp, C. L'abbe, M.Y. Hu, and D. Errandonea. (2004) Phonon density of
states and elastic properties of Fe-based materials under compression.
Hyperfine Interact., 153, 3.
21. Tschauner, O., S.-N. Luo, P.D. Asimov, T.J. Ahrens, D.C. Swift,
T.E. Tierney, D.L. Paisley, and S.J. Chipera. (2004) Shock-synthesized
glassy and solid silica: Intermediates between four and six fold
coordination. High Pressure Res., 24, 471
20. Xu, J., D. Y., S.D. Jacobsen, H.K. Mao, R.J. Hemley, J. Zhang, J.
Qian, C. Pantea, S.C. Vogel, D.J. Williams, and Y. Zhao. (2004) Powder
neutron diffraction of wustite (Fe0.93O) to 12 GPa using large
moissanite anvils. High Pressure Res., 24, 247.
19. Xu, J., D. Y., H.K. Mao, and R.J. Hemley. (2004) Large volume
high-pressure cell with supported moissanite anvils. Rev. Sci.
Instrum., 75, 1034.
18. Zhao, J., W. Sturhahn, J.F. Lin, G. Shen, E.E. Alp, and H.K. Mao.
(2004) Nuclear resonant scattering at high pressure and high
temperature. High Pressure Res., 24, 447.
17. Errandonea*, D., F.J. Manjon, M. Somayazulu, and D. Häusermann.
(2003) Effects of pressure on the local atomic structure of CaWO4
and YLiF4: mechanism of the scheelite to wolframite and
scheelite-to-fergusonite transitions. J.Solid State Chem., 177,
1087.
16. Errandonea, D., Y. Meng, D. Häusermann, and T. Uchida. (2003)
Study of the phase transformations and equation of state of magnesium by
synchrotron x-ray diffraction. J. Phys.: Condens. Matter, 15,
1277.
15. Errandonea, D., A. Segura, F.J. Manjon, and A. Chevy. (2003)
Transport measurements in InSe under high pressure and high temperature:
shallow-to-deep donor transformation of Sn related donor impurities.
Semi Cond. Sci & Tech, 18, 241.
14. Errandonea, D., M. Somayazulu, and D. Häusermann. (2003) Phase
transitions and amorphization of CaWO4 at high pressure.
Phys. Stat. Sol., 235, 162.
13. Errandonea*, D., M. Somayazulu, D. Häusermann, and H.K. Mao.
(2003) Melting of tantalum at high pressure determined by angle
dispersive x-ray diffraction in a double-sided laser-heated
diamond-anvil cell. J. Phys.: Condens. Matter, 15, 7635.
12. Hu, M.Y., W. Sturhahn, T.S. Toellner, P.D. Mannheim, D.E. Brown,
J. Zhao, and E.E. Alp. (2003) Measuring velocity of sound with nuclear
resonant inelastic x-ray scattering. Phys. Rev. B, 67,
094304/01.
11. Lin, J.F., S. Shu, H.K. Mao, R.J. Hemley, and G. Shen. (2003)
Amorphous boron gasket in diamond anvil cell research. Rev. Sci.
Instrum., 74, 4732.
10. Lin, J.F., V.V. Struzhkin, W. Sturhahn, E. Huang, J. Zhao, M.Y.
Hu, E.E. Alp, H.K. Mao, N. Boctor, and R.J. Hemley. (2003) Sound
velocities of iron-nickel and iron-silicon alloys at high pressures.
Geophy. Res. Lett., 30, 018405.
9. Mao, W.L., and H.K. Mao. (2003) Hydrogen storage in molecular
compounds. Proc. Nat. Aca. Sc., 101, 708.
8. Mao, W.L., H.K. Mao, P.J. Eng, T. Trainor, M. Newville, C.C. Kao,
D.L. Heinz, J. Shu, Y. Meng, and R.J. Hemley. (2003) Bonding changes in
compressed superhard graphite. Science, 302, 425.
7. Mao, W.L., H.K. Mao, C.S. Yan, J. Shu, J. Hu, and R.J. Hemley.
(2003) Generation of ultrahigh pressure using single-crystal
chemical-vapor-deposition diamond anvils. Appl. Phys. Lett.,
83, 5190.
6. Meng, Y., M. Newville, S. Sutton, J. Rakovan, and H.K. Mao. (2003)
Fe and Ni impurities in synthetic diamond. Am. Mineral, 88,
1555.
5. Song*, Y., Z. Liu, H.K. Mao, R.J. Hemley, and D.R. Herschbach.
(2003) High-pressure stability, transformations and vibrational dynamics
of nitrosonium nitrate from synchrotron infared and Raman spectroscopy.
J. Chem. Phys., 118, 2232.
4. Song*, Y., M. Somayazulu, H.K. Mao, R.J. Hemley, and D.R.
Herschbach. (2003) High pressure structure and equation of state of
nitrosonium nitrate from synchrotron x-ray diffraction. J. Chem.
Phys., 118, 8350
3. Yoo, C.S., V. Iota, H. Cynn, M. Nicol, J.H. Park, T.L. Bihan, and
M. Mezouar. (2003) Disproportionation and other transformations of N20
at high pressures and temperatures to lower energy, denser phases.
Phys. Chem. B, 107, 5922.
2. Gregoryanz* E., A.F. Goncharov, R.J. Hemley, H.K. Mao, M.
Somayazulu, and G. Shen. (2002) Raman, infrared, and x-ray evidence for
new phases of nitrogen at high pressures and temperatures. Phys Rev.
B., 66, 224108.
1. Deb*, W. Wilding, M. Somayazulu, and P.F. McMillan. (2001)
Pressure-induced amorphization and an amorphous-amorphous transition in
densified porous silicon. Nat. Mater., 414, 528
result of work done at other facilities
by HPCAT staff
